1 - 11 of 11 Posts
Anyone running an Edelbrock carb on their roadrace car? I put a 306 in a 2000. It has a rpm airgap with a 600cfm edelbrock. Any issues in the corners in regards to fuel delivery? $$'s matter so hoping to make it work.
I tried one a looooong time ago and had trouble getting it to work. The odd shape of the fuel bowl led to fuel delivery issues.
HTH,
DaveW
carb
Was thinking the same thing. I guess Holley DP is the way to go. Will give it a try though since I already own it. Almost new carb and may be for sale.
We had a Edelbrock on our Lemons car and it really stumbled in the corners. We had to raise the float a lot to try to fix it but it did not help much. Get a center hung float Holley.
well we are on the subject of carbs here.. what mods are needed to go road racing with a holly? what have you guys who have run carbs found to work well?
Even though I only autocross, I haven't run into a fuel starvation problem with the side hung float Holley carburetor on my car. I had plans to get the center hung float bowl conversion kit but it's hasn't been an issue (sticky 'R' tires even) so far.
A tracked car that runs at higher sustained speeds is another matter but I thought I'd weigh in with my experience.
carb
Are the center hung versions completely different bowls or just the float itself?
Center hung float bowls.
Circle track plastic float.
Cut right side of float to match angle on left side.
Install hose from front vent on top of carb to back vent.
Cut hole in top or sides of said hose so it still vents.
Make sure air cleaner doesn't seal vent hole in hose shut.
Set float level very precisely. If it takes less than 15 minutes, you are doing it wrong. :)
GO have fun. :)
DaveW
Different bowls. Should be easy/cheap to find.
Talking to some of the GT-1 mechanics at the Runoffs, they don't seem to have the same troubles autocrossers do with carbs. The turns are much gentler (SP?) and not done nearly as often. As an illustration of what happens to fluids in an autocross car during violent 1.5g turns, I have some old in car video where my remote brake resivoirs were visible. (I wish I could find the video now) The fluid was visibly at 45 degrees or more for almost the entire run.
I ran a side hung Holley for a while way back and it worked fine for me too. As the car got faster, it started to be more troublesome. I went to the center hung with a new motor and stayed with various versions throughout the years.
All that aside, the Edelbrock fuel bowl is very oddly shaped and I would expect much more troublesome than any Holley.
HTH, IMO,
DaveW
If you end up buying a new Carb,
I Auto-X my 84 with a holley 570 CFM Street Avenger and have not had any problems. The Street Avengers are all Center Hung and are availabe in Different CFM's and for a decent Price at Summit Racing.
Just my 2 cents,
Scott
carb
Thanks for the info. Is the 570 carb enough for my mild 306. It has gt40x heads, 303 cam with an airgap intake. Should I get a 600cfm?
1 - 11 of 11 Posts
