I have a 91 coupe it has 306 h/c/i with 5speed. has southside lowers,upr uppers,moroso trick springs in back,stock shocks and struts, stock gt front springs. I drove the car yesterday on the highway, it has 26-10.5 mt et streets, I had 14 psi tires. i left and the car hooked at first then it felt liked it hit the bump stops and unloaded the rear tires, went to second gear hooked at first and did the same thing. what else can i do to get it to hook up. any help is appreciated. thanks
I think a set of new shocks may be in order. The rears are most likely too soft on the compression and too hard on the rebound to work well with those trick springs. Southsides hit so hard they often unload after the initial bite.
