Goin drag only and would like to replace my steering wheel in my 1993 GT. Does someone make an adapter for this? If so, any part numbers?
Go find a steering column from an 87-89, preferebly one with tilt. Then swap it out (around an hour with an extra set of hands) and then you can select any steering wheel you want. I have done this on two cars and had good luck.
Brandon
I know this is an old thread, i did a search and this is the only one that popped up. I have 90 airbag column, any idea where I could find an adapter to put different wheel on my track only car? Thanks.
Grant also makes an adapter (have one in my car) but it was there when I got it. No part number. I recently went from a non tilt 90+ column with a 14 inch round steering wheel to a tilt column with 13 inch wheel and flat bottom (MORE LEG ROOM) and its MUCH nicer, and I like the turn feel with the smaller wheel to.
