1 - 20 of 21 Posts
does anyone have pics of this? does the frame have to be notched? is it better to shorten the axles?
Not an answer to your question but a reference...
That was 325/50 MT radials on a 15x10 with 6.5 backspacing and 1/4in spacers on each side. The tires were almost sitting against the rear coil springs even with the BFH to the inner fenderwells.
I couldn't stand the way it looked and went back to a 275/60 on a 10in rim.
I'm no expert but I don't see why the 325's wouldn't fit with the minitub and coilovers and a 7.5in bs rim.
Thats exactly what I plan on doing. I already have the coilovers welded in. If I widen my existing rims (from 5.5 to 7.5) to accept with 325, It looks like it will miss the frame by about 3/4". My problem is going to be the gas tank. Its a Glens Performance and i'm not getting rid of it. When I install my tubs, i'll prolly cut the frame anyway, just for the added width.
I will be close I have 325's and the car is mini tubed rear was narrowed 2 1/4" each side and the tires tuck under very nicely with about 1" clearance all around and the rear is lowered .
that looks nice. did you have to notch the frame?
Yes I did I wanted all the room I could get to fit the 325's and lower the car down so it did not sit so ass end high . Go here to see more of my build so far http://www.cardomain.com/ride/2474570
325/50/15 on 15x10 with 7.5 BS on mini-tubbed coupe with stock 8.8 width 9" rear.
The tire is about flush with the fender lip, I never really dropped it more than about an inch or so above the lip. The round part of the tire would probably rub the edge of the lip. But I switched to 28x10.5 ET Drags and on the same wheel, they will tuck inside the fender.
White90GT, do you mean it would rub the inner factory quarter lip or the outer painted side?(as in you cut away the inner lip). I plan on having my wheels widened to 11", it will widen the overall section to about 13.5" but will shrink the sidewall bulge sucking the tire in tighter from 1 1/4" to about 3/4".
Not the inner frame lip, still got like 2" of space inside there, you could fit a 15x12 with like 8-9" backspace LOL.
I mean the inside of the outer fender lip, the part that you normally roll in for when the tires rub.
Discussion Starter #14
Here's a link with pics of my junk. I'm the Blue 79 Stang (DOT #21). Mickey 325/50 DR's with Billet Spec. 15 x 10 with 7.5" backspacing. Stock width 8.8" rear with the inner wheel wells moved-in and the outter lips rolled. Stock rear frame rails. Looks ok and works. Last week in the mid 90's heat went a 1.37 with a [email protected] in street worthy trim.
Tater
http://tmkphotography1.smugmug.com/gallery/8896919_9Cx2e/1/590143041_xQmhS#590144881_dmERy
for some reason i couldnt make the pic larger. do you have anymore?
Ideal wheel backspacing /w Stock length rearend /w 325 radials is 8" with a minitub
That way it fits inside fender lip and you can lower the car down without rubbing the fender lip.
i have 10" wide with 6.5" b.s. and 2" off the rear on both sides.it's mini-tubed and the frame is notched. we also clearanced the front of the wheel well to fit 315's if needed
Banned
i used a 325-50-15 on a 15x10 with 6.5 bs with stock 8.8 and mini tubes, and compition eng. rear coil over kit. I rolled the 1/4 lip on the inside and the height of the 1/4 lip to the grnd is 27" i think i heard 26" is optimal but i dont have a anti-rollbar yet so it would scrub while driving through a turn. street car here, drive it to work everyday.
Discussion Starter #19
do you have pics?
1 - 20 of 21 Posts
