Thinking bout selling them and seeing if anyone is interested. They have about 7,000 miles on them. Great cams I like them a lot, just been looking at something a little different. Cams are Comp Cams and a VSR set so you WILL need springs and retainers. You get a noticeable difference at idle but not anything radical. These are good for someone who wants just a little bit more grunt with out alot of noise. Cams where purchased from Evolution Performance.
Asking $400 + shipping, If within 200 miles from Corpus Christi Tx I will meet half way.
•Basic Operating RPM Range: 1,000-6,000 <-- says 6'000 but I was still making power till 6400 when I let out on the dyno.
•Intake Duration at 050 inch Lift: 222
•Exhaust Duration at 050 inch Lift: 235
•Duration at 050 inch Lift: 222 int./235 exh.
•Advertised Intake Duration: 261
•Advertised Exhaust Duration: 278
•Advertised Duration: 261 int./278 exh
•Intake Valve Lift with Factory Rocker Arm Ratio: 0.490 in.
•Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.480 in.
•Valve Lift with Factory Rocker Arm Ratio: 0.490 int./0.480 exh. lift
•Lobe Separation (degrees): 115.5
•Grind Number: XE261H-115.5
shoot me an email i read it more than this site?? [email protected] im not anywhere near texas but lets make a deal if you want these gone? thx..
I'm interested. Are they out of the car yet? Who did the install?
