I have a pair of MM Cambercaster plates I originally got them for an 87 but now I have a 93 I want to put them on. MM shows 2 different part numbers but the parts look identical. even the instructions are the same.
So what is the difference between a 87-89 strut tower top and a 90-93 top?
Thanks,
Mike
the holes on the 87-89s where the plates move are smaller than on the 90-93's. they have more room to move around on 90+ i think. double check me though, go to maximum motorsports site and see, i think they say the differences
The holes in the top of the shock tower are slightly different. These are steel UPR plates, but you can see the difference.
--Vince
The three mounting holes are the same diameter, but Ford moved the center to center locations of them slightly. You can probably install the c/c plates in your car with a hammer, but you're not going to be able to move them very easily to adjust them.
I suggest that you call MM. They can probably sell you just the plates pretty cheap. Just explain the situation to them and I bet they will help you out.
--Vince
