1 - 1 of 1 Posts
i have a 306 in a fox body. it is a 5 speed with a 327 gear. the motor is fuel injected with 9.5 compression. runs on pump gas. my question is. my cam is a hydr. roller from erson. the specs are 286/294 dur with 544/544 lift. I think the center line is 112. I am in the process of installing a 70 m turbo with .68 housing. 42 pound injectors and pro m mass air meter with pro-m efi management. is this cam okay for the turbo setup. thanks. 99% street driven with a/c, power steering, power brakes and heat. thanks for the help in advance.
1 - 1 of 1 Posts
