I've got my MM K-Member and control arms installed, and I went to install the Steering Rack and the directions said to use the .35" aluminum spacers between the rack and the K-Member for clearance (I'm using the standard offset control arms). Do these .35" aluminum spacers come in the kit? If so, I didn't get them, but I want to make sure they were supposed to come in the kit. I would have assumed they would have come in the aluminum off-set rack bushings bag, but they just weren't there.
Thanks in advance!
They're listed in the parts list, so they should come with the kit. If you call MM I'm sure they will send you a pair.
Spacers
I opened my kit the other day and both thickness spacers were in the kit... Sorry bro.
Mine came with several spacers that were different widths. I think I had to use the thick spacer and a thin one to get the rack to clear. The rubber boot on each side was hitting and I did not want it to rub a hole in it.
Stephen
