I purchased a C4 from someone and may have not gotten what I paid for first the bell housing bolts would not torque up twoo stripped (can they be heli coiled) second should you be able to pull the input shaft out?
you should be able to pull the input shaft out, sometimes they are really jammed in there, especially if it has a aftermarket forward clutch drum
