mine did the same thing, i got one of the catch cans from tci but i wouldnt buy another one if you pull the vent tube off its the correct size for a 1/8 ntp tap, tap the hole get an 1/8 ntp fitting and run it over to a catch can. The tci is supposed to bolt to the back pan bolts but my exhaust was in the way and had to make a bracked to hold it would have been cheaper just to get a plastic catch can and run a line to it.
i had a built c4 years ago i just ran a hose up the dipstick tube and iirc put a breather on it. make sure its not too far overfilled also
