change to automatic pedal assembly and on the trans x member you have to cut the spot welds and move the center back and forth until it fits
Administrator
You can also just put the clutch pedal down and under the carpeting, that way the car can be converted back to a manual at some point if the owner so chooses...
You might need a BFH for the trans tunnel also... On an Manual car anyway..
The stock driveshaft will work.
You will need:
1. Cut spot welds off x-member so you can adjust the x-member to line up with transmission.
2. Shifter (Hurst, Cheetah, B&M, etc.)
3. Bellhousing (I suggest 157T) Smaller to fit in the tunnel (JW makes a nice bell)
4. Flexplate (if stock 50 oz. other whatever your motor is balanced at) (TCI, Performance Automatic, etc.)
5. Convertor (If going 157T go with a 10.5 Bolt circle) I would talk with a trans company like Dynamic, Redneck, Coan, TCI, Performance Automatic, PTC, etc to get a convertor for your particular application)
