How do you guys feel about them. Will they hold you back from making any power with a turbo. Ive done some reading on hear about idle problems with them. Im just couious on power potential with them. Thanks
i run one with no idle or drive issues drives around like stock bad part is 42tube is the biggest they go same tube for the 60lbs.i curently have 42s and plan on steping to 60s
I had idle problems with them when I had larger injectors....switch to SCT MAF and haven't had troubles
