Is anyine interested in a c clip elim install? Before i ordered my parts this wasa somthing that i had searched a bit and could not find too much information on. So here goes
Take the drum off
remove the 4 center nuts there are bolt heads on the back
http://i278.photobucket.com/albums/kk110/smurfmobile8586/Cars/P1010042.jpg
Here is what it looks like
http://i278.photobucket.com/albums/kk110/smurfmobile8586/Cars/P1010041.jpg
Clean everything up, have to remove the wheel bearing and the axle seal next is the part that had me really nervous CUTTING i used a air powered cut off wheel and left some then sanded it down with a 5inch orbital sander
http://i278.photobucket.com/albums/kk110/smurfmobile8586/P1010011.jpg
http://i278.photobucket.com/albums/kk110/smurfmobile8586/P1010012.jpg
http://i278.photobucket.com/albums/kk110/smurfmobile8586/P1010014.jpg
You need to edit and put Img codes insteed of links
When I did mine you are supposed to leave a about 1/4" of tube sticking out. It must be square and true when finished. This holds the c-clip elem. in place and helps to seal it all up. Are your instructions different?
yea the darn scanner will not scan the page i was trying to post it up but will end up taking a pic and see how that turns out. the ones i got told me to cut off everything up to the bump (Strang calls it a backing plate register). i will try to get the scanner working and will be posting more pics and be using img code for those people who don't wanna click on a link
I can't find the instructions for the mosers. Looks like the Strange setup is a little different. It looks like you got it right. Just enough for the brake backing plate to mount on and thats it.
