TFS Top End. V2 s-trim. Makes 10psi.
Making some changes for summer, bigger pulley, and I want to changed the breather set up.
Current set up:
Breather on the pax side VC
Lower intake has a hose running to a small breather
Upper intake plugged
TB and filler neck plugged
What I'm shooting for:
Works good, car doesn't see lots of idle time, oil is changed more often than it ever needs to be.
During the summer the cabin gets stinky when it gets pretty hot out.
I would like to stop this.
Plan:
VC breather that uses a ball to close in vacuum and open in boost.
Same thing with the rear, does a smaller filter exist?
Does this set up cause any problems?
Current set up:
Plan:
