I am planning a brake upgrade for my Mustang. The current set up is from a 1998 V-6 (including changing over the nuts on the factory hard lines). Here is the upgrade I am planning. If you see a problem or have a better idea let me know. The car is strickly street driven and I have a budget. I know there is better systems but they are much more expensive.
Front
FRP Cobra Calibers 213.99
NAPA Rotors 2*32.99
Russell 5 hose kit 131.69
Rear
FRP Rear upgrade kit 170.88
I dont know what rear brake pad I will use, but I would want it to match the factory ford front pads. All the prices are from Summit Racing. I spoke with a couple of people if the hose kit will work and I was told that the kit uses the coarse banjo bolts in the front so they will work if the calibers were manufactured after 2003 if not then I will have to get a fine thread banjo bolt.
NAPA ROTORS = BAD
YOU CAN GET FACTORY COBRA/BREMBO ROTORS 2 FOR $140 SHIPPED TO YOUR DOOR
CALL: DAN @ GREAT LAKES 1-800-451-7558 EXT 227
