I have a 1993 foxbody that I have done a coyote swap along with cobra hydroboost. The rear has been converted to cobra rear disc and the front to brembo 4 piston calipers. Can the 3/16 lines handle this or go I need to step up to 1/4"? I have not seen 1/4 line kits for a fox.
brakes are a closed system. you can put on 8 piston calipers and still use 3/16 line. it really doesnt make a difference. so to be blunt, 3/16 lines will work just fine
Mike
