1 - 10 of 10 Posts
Has anyone used speed bleeders? I used the mityvac last time and wasted a lot of fluid and quite messy.
I have speed bleeders on my brakes(Cobra brakes on Fox stang). I'm satisfied with them.
They make 1 person bleeding really easy. Crack a bleeder and slowly/repeatedly pump the brake pedal. Check fluid level frequently.
When done with corner, move onto the next. All 4 corners can be done in less than 10 minutes(after jacking up and removing wheels).
I have read that after a few times of loosening/tightening the bleeders, the "anti-leak" sealant on the threads can wear away, which can allow air to be pulled back past the bleeder. I think you can buy more sealant, but not sure on that. I've only bled mine one time when I originally put them on.
I remember back in the day when I had to do one-man brake bleeding and didn't have mityvac(or speed bleeders). I pumped up the pedal and wedged a 2x4 between the pedal and the front seat. I would then go to the respective wheel and crack the bleeder(lather/rinse/repeat). That took a solid 10 minutes per corner. That sucked.
Been using them for 10 years on my track car and love them. Probably have cracked them open over 100 times. They do seep around the threads a little when open but it doesn't seem to cause any problem.
how many pumps do you do per wheel, and how many times do you repeat the process?
I do somewhere around 20 pumps for the rears and about 1/2 of that for the front as they are closer to the MC so there's not as much fluid in the lines. That will empty a bottle of Motul 600 and I'm done. I do it in the spring right before track season starts and I'm done for the season. When I was using the stock calipers I was doing it all the time because I was boiling the fluid frequently.
I used speed bleeders for a while but didn't feel comfortable with the seepage.
Switched to a motive pressure bleeder and have been very happy with the results. Probably the same amount of time, or shorter, to bleed all four than with speed bleeders.
I too like the Motive Bleeder. No seepage issues and its quick.
thanks blurr
for the motive guys which kit are you using the 0107?
0107 is appropriate for the master cylinders with 3 tabs. It is the one that I use. You can use it on other vehicles too with the appropriate adapters (sold separately).
1 - 10 of 10 Posts
