I have a carbed 351w and I found a drivers side mount Procharger F1R and it came with a Vortech Mondo BOV and discharge tube. I am going with a blow through carb setup. Will the Mondo BOV work or do I need an Open Procharger Big Red. I see they come in open and enclosed.
I would get the "Big Red" from Procharger. Depending on how you have it pulleyed, at light throttle and higher RPM hat pressure builds and causes high fuel pressure which pushes past the floats and makes it run rich. I have an F2 blowthru and wish I would have put 2 bypass valves on it.
