Last night I was following a friend in my SN95 and managed to snag the K member on the pavement after one of those roller coaster style dips country roads like to have
I'm on B springs with bilstein struts, did this happen because the spring rate is on the low side or is it just a freak occurence?
I've never had anything like that happen in my cars before. I wanted to lower the car another half inch with MM front coilover kit and new rear springs, but now I'm not so sure
I feel the spring rate won't help if I take away ground clearance at the same time
I'd rather not have this happen again, and I'd really hate to have it happen more often
Super Moderator
Those springs are the practically the same rate as stock, but a lot shorter. If you want to lower it even more, you're going to need a lot more wheel rate, which shouldn't be a problem. The wheel rate on those B's is around 260 lbs. A 350# coilover would probably do the trick and not rattle your kidneys.
Country roads up here have such a huge crown in the center of the lanes I need to literally drive down the center line to avoid scraping the k-member/TA and I'm only about an inch lower than stock at 26".If I hit a dip on these roads there's no doubt I'd be in the pickers.
I guess what I'm saying is are you sure it's not road conditions instead of a suspension issue?
Like MFE stated,If you are planning on going lower(unadvised)then an increase in spring rate is needed.IMO,Before I increased to say a 350# coilover front spring on a driven street car I would raise the ride height to solve the issue.
Before switching to 250# up front(have 225# ready to be swapped in) I had 275# coilovers and the ride was almost unbearable,but the wagon trails up here in town suck and I'm getting to be an old fart.
How old are those Bils? I once started bottoming out at a certain track but it was because I was using some bull#### struts that were worn out. I bought new Bils and it never happened again.
I mean the big drop is what got it that low but it might be because of a low spot left/right too.
I didn't realize they were that close to stock spring rate, I bought them to keep the car fairly comfortable
Also I bought these front struts the same time I got the springs, about eight months ago. Rear bilsteins are older
I want to get forward offset front coilovers, just still debating going lower. I know it'll ride better only lowered 1 inch, but it would look really good that extra half inch lower
I mostly came here to see if this is just part of the territory and it sounds like it is
