1 - 13 of 13 Posts
In my quest for traction, I bought a Holley 3 port boost solenoid kit.
Now I'm rethinking how convenient it would be. I planned on doing dome pressure but watching the MAP for safety. I sort of thought I could use a small air tank with a regulator, because I want to run a 10-15 psi spring to set base pressureand I'm only going to max boost at 25 or so. I don't think I need that much pressure.
So is using the Holley OK, or are there good stand alone? I wanted to pull boost back until the tires hook and suspension loads and then let it fly, the exact amount depending on traction. The Holly would require use of my laptop to change boost, which is not terrible to do.
I run the holley 7763 grid boost controller and it is very easy to use, just need to create a new file for each change
Tnx. I have the HP, so I guess this is not compatible.
sorry, didn't know you had the HP
:smile2:
the HP ecu has the same boost controller built into it already. you just have to wire it and get the solenoids and CO2 bottle with gauges. It is a great controller. Not that hard to set up
:smile2:
Do I have to use CO2 tanks? Can I just use an air tank I recharge from my compressor?
yes... doug vanstorm uses an air tank in his car
  • Like
Reactions: TomR
Any idea how big the tank has to be? I would think not too big, right? All it has to do is bleed into the wastegate for a few seconds during a run? Maybe a one gallon tank?
think his is a 10 gallon...
Higher pressure with CO2 so smaller tanks.
The best I can get pre-regulator on my air compressor is 175psi. So a 10 gal tank is about right.
co2 bottles are not that expensive, and don't cost that much to refill. you can go for weeks on a 5lb bottle. you do need to regulate it down to approx. 100lbs. an air tank could get down below that fairly quickly.
we use 2.5lb bottle from the local liquor store at 20 bucks an exchange. we keep a spare in the trailer but we normally see 3 bottles a season
  • Like
Reactions: TomR
Discussion Starter #13
It looks like CO2 is the way to go.
1 - 13 of 13 Posts
