Bought a grimmspeed mbc and wanting to mount in cabin. How far can you mount the mbs from the wg and boost source before you run into problems? Want to hear how far some of you ave mounted your mbc's and did you run into any issues? Boost spikes? if so how much ova boost?
I heard 3' tops but I'm about to press my luck on that.
You want it as close to the source as possible . I just installed a electronic boost controller and had about 2 1/2ft of hose and noticed a difference from using a shorter hose . I ended up moving the solenoid as close as I could to shorten the hoses. I did look at some manual boost controllers that had a cabin add on . It was a cable that hooked to the controller in the motor compartment and routed to the cabin. But all the cable did was turn the nob or replace the nob on the controller.
The hallaman has a cable adjuster. I had one but sold it to get this grimmspeed mbc. Wanted something a little more accurate wit a scale and knob that clicked.
