I just bought an on3 kit for my fox, i have a pro-m 75mm bullet maf.
Will it work in a blow through? Or will i need to buy a blow through maf?
Yes, it will work in blow through configuration. Sometimes you can run into early pegging issues since the bullet's are not setup/calibrated for blow through, this is why I suggest the a Protube is used instead. I believe on that kit you will need just the sensor that goes onto flange.
Thanks, Chris
Thanks, Chris
Thanks for the reply, just to make sure are you suggesting this part <PMAS 3’ PROTUBE Mass Air Meter 42lb Calibration 89-95 Mustang LX/GT< - PMAS Mass Air Meters
or something different?
My car is a 90lx, i will be using 42lb injectors and it will be blow through.
thanks
What MAFs are you guys on here using on blow through?
Anyone running with sucess with out a tune? Just maf, injectors, lock timing, and play with fuel pressure?
thanks
Last few ON3 Car's I have tuned, I believe with the ON3 kit it has a weld on flange for sensor, if your kit does then the Protube wouldn't be correct for that setup, We also like the HPX slot style meters they are great in a blow through application.
If you could put up some pic's of piping I would be able to tell for meter, We have what you would need just have to make sure for application.
Thanks, Chris
Ill put pics up when it gets here, thank you
