1 - 8 of 8 Posts
so i think i might have blown a head gasket on the dyno yesterday. cooling system got so pressurized that the overflow overflowed! but i dont have any milky colored oil on the dipstick or oil fill cap. ive only blown a head gasket once before on my vortech set up and that time it was clear because there was the milky color. this time i dont see that so im confused. is it possible to blow a head gasket and not send coolant into the oil pan?
btw, im running a stock 86 long block with Felpro 9333pt1 gaskets and arp studs. i have a 5 pound spring in my wastegate but the gate stuck the other day and i hit over 16 lbs for a split second. i guess it would be possible to lift the head some but i dont know.
anyone out there have some more knowledge on this than i do? thanks
Formerly eades5.0
Yes very common, I think most of us have been there unfortunately.
I always use a tool that checks for exhaust gases in the coolant...that will tell you 100% if it's blown. I'm a knuckle head and bubbles never convince me cause I'm in denial HAHA
Good luck man!
thanks guys for your responses! looks like that boost spike did me in! well that and the fact that i wasnt 100% tuned. it was safe for the low boost setting i was suppose to have but not the spike
Good luck man!
Where did you get this tool? I heard there's such a thing as test strips... but all the big parts stores had never heard of them.
1 - 8 of 8 Posts
