Im in the process or going from a kenne bell supercharged 5.0 to a blow thru turbo car.
I am currently running a 255 fuel pump, and want to know what i need to do to convert my current system to a system that will support a blow thru carb set up. any help would be great.
thank you
aeromotive 13204 regulator
csu or c&s carb
a1000 pump
10an feed
8an return( actually i prefer 10an here)
or
aeromotive 13202
same carb
magnafuel 500 pump
12an to pump
10an to reg
10 an return
depends on how much you want to make...the first combo works good up till about 800 ive seen..
