Is there a fr and Rr coil over kits that fit bilstein shocks?? for a 93 5.0? also what spring rate should I get? want to be inbetween handling and drag? thanks
David
MM makes a kit for the bilsteins. Call them for suggested spring rates as it matters what suspension setup you currently have, plan to have, and what you plan to do with the car.
Edit to add my spring rates:
For my 50% OT car with a Three Link setup, MM recommended 325 lb/in up front with 250 lb/in out back.
