Everyone is saying that to get 300rwhp from a small cross section head is going to take more duration, where a large cross section head will need less duration. Of course this is assuming that you're comparing 300rwhp for both (you said 300hp for large) I'll guess that the lower duration cam larger cross section will be more streetable.so, once again, is the 3200lb 300rwhp small cross section motor going to be more "streetable" than the 300hp large cross section motor, in the same car, with the valve events optimised to take advantage of the setup?
And Erik you know if that you, or Buddy, or myself are doing the cam it would be ok. The problem is saying "Too Big" is that it just depends. No, I say again, No I am not advocating a 305cc Victor or a 260cc Yates head on a 306. But an AFR 205, Perf RPM and the right cam would be a friggin blast to drive on a 306 and as Erik has said, it gives the customer an option for more later. I said this in another thread as well.racer7088 said:I like to a go a little bigger than some people on heads and then run a smaller duration cam in it as well just so that the customer has the option of more later
Yes big power and a good amount of nitrous...these 165's will be far from "out of the box" when completeracer7088 said:It depends on what you want. If you are looking for really big power then yes the 165s are way small. If you have an efi longrunner deal that's not gonna make a lot of power anyway they will give you more area under the curve possibly but even then I think the 185s would be better to start with probably.
THEN.........hmmm guess my 165's on the 364 will be junk...I better sell them off!!!
c'mon mat..........you know your heads wont be 165cc's when neil is done with em.......and if they were box stock 165's, they would certainly be small for a 364" combo........ now, will vic jr's be too big for my 302 ?super pimp Neil Erickson ported 165's in progress
Jay Allen said:And Erik you know if that you, or Buddy, or myself are doing the cam it would be ok. The problem is saying "Too Big" is that it just depends. No, I say again, No I am not advocating a 305cc Victor or a 260cc Yates head on a 306. But an AFR 205, Perf RPM and the right cam would be a friggin blast to drive on a 306 and as Erik has said, it gives the customer an option for more later. I said this in another thread as well.
No to the guy asking about is a 205AFR qualifies as a Big Head on a little engine, that depends. If it is a very small stroke and a larger bore, it *could*. A 3.3 stroke and a 4.155 bore yields 358 cid. This is getting close. But if it is 4.03 bore and 3.5 stroke, no it is not.
