Thinking about putting a s366 on my car.
Was wondering if anyone else has used one, and were did it spool?
Also do y'all think it'd be worth swapping a stock cam in over the b cam that's in there now?
i run two of them on my 331 and im at full boost (25psi on wastegate spring) by 4k. pretty sure i can get them to spool faster once i turn on my boost controller. currently hooked up but not turned on
where it spools will be greatly effected by the turbine AR
Need more information on your set up, for a bone stock 302 I think the s366 is a great turbo if you have realistic goals.
A b cam would not be my first choice , if you can get your hands on a F cam, its the better one of the alphabet cams for turbo aplications. Or you can use a stock cam and throw on some 1.7 rockers, have heard of great success with that combo.
Ported gt40s b cam and a t5!
With the on3 70/65 .68ar it's all in at 11psi maybe 5-600rpm after I smash the gas. I'd hate to lose that. But what am I giving up top?
I know the b cam is hurting me it was slower with it over the stock cam and 1.7's on motor.
But thought the turbo would over come it.
