What's the easiest/fastest/cheapest way to drain old gas from an 87-93 tank?
I left about 2 or 3 gallons in the car for a year and a half, while it's been down, and I need to get it out before I fire it up.
What's the easiest way?
Thanks!
Shawn
The only way I can think is to disconnect the fuel filter and turn the key to the "On" position to try to prime the fuel system. It should pump the fuel out.
that's what I was thinking...
how much of a problem would varnish be if the gas sat for 1.5yrs?
Should I just remove the tank and clean it out?
Shawn
