What amp rating for the kill switch should be used with a 3g alt?
Just use the one from Summit or Moroso. It'll work fine. Your alternator will only put out the voltage that's needed so you wouldn't need anything different than what you would for a stock 2G alternator.
Summit part number : SUM-G1432
20 bucks
