21 - 28 of 28 Posts
Discussion Starter #21
I ran positive and negative 1/0 cables through car, driver side along beside the rear brake wires, fuel pump, etc, then through the boot next to the speedometer cable.
Discussion Starter #23
why did you run a negative cable all the way back up front.?
To connect it to the original location, otherwise you have to worry about the grounds, especially to the eec. I bought both cheap off of ebay, I think 50 cents a foot.
Do it like my diagram and it'll work perfectly. The only concession I would suggest (definitely NOT necessary tho) is moving the solenoid to the rear like the M.A.D. instructions say.
Ground from the battery to the rear subframe, up front ground the block to the subframe, then the sideskirt to the subframe as well.
http://buffhomer.corral.net/custom.html
::edit:: Ok doesn't seem like the member pages are working. Here's the diagram:
21 - 28 of 28 Posts
