1 - 13 of 13 Posts
Will I be able to get away with just a Bama custom tune
I want about 450 hp Or will it need to be dyno tuned
Combo is 89 302 mustang
On3 base turbo kit 12# of boost
Vavle job, milled, port exaust and intake side gt40p heads
Gt40 intake
F-303 cam
75mm throttle body
No smog
Electric fan
60#injectors
Stock freshly rebuilt bottom end
For a turbo application, your best to have it tuned on a Dyno in your area, or work with someone remote tuning. We have many Quarterhorse user's that have the ability to finalize there calibration that will be needed rather then a canned tune and or mail order chip.
Yes. You tell the tuner about your setup. He programs his tune onto a chip, and you install chip. I have one on my car.
i know that but with a chip he mails it to you.. and if its really far off or needs some serious tweaks you gotta pull it out and ship it back to him and stuff..which in hindsight is kinda pointless to do all that when you could have just got tuned locally..
For a turbo application, your best to have it tuned on a Dyno in your area, or work with someone remote tuning. We have many Quarterhorse user's that have the ability to finalize there calibration that will be needed rather then a base tune and or mail order chip.
This is the wa i went and i could not be happier... Chris at poweradder should be your first and only call.
Gt40 intake
F-303 cam
75mm throttle body
No smog
Electric fan
60#injectors
Playdoh302,
Unfortunately, we won't tune for a heavily modified Mustang like yours, even as sick as it is! When you have extreme mods like this, you definitely want to go with a dyno tune. That is the only way to truly have a safe tune since there's so many different variables that can come into play. The tune could really go in a few directions, especially for drive-ability. It's much easier with the Stang right in front of your to fix these issues.
If you need a recommended dyno shop in your area, feel free to hit one of our Bama Specialists up on the number in my signature. Good luck with this mean Fox!
Shane
Or
Set timing to 19 deg, pull spout, FP ...to 40ish, watch A/F's 11.5's under BIG boost...GTG
This will get you by untill you can find a Dec tuner with a dyno or MS
I have ran a year this way.....Just to lazy to drive the 3 hrs to dyno..LOL....but I'm happy with the results
BUT really the Dyno is the only way to go!!
1 - 13 of 13 Posts
