1 - 9 of 9 Posts
I have an '88 that I believe has a bad ECM, but I wanted to get feedback on this before I make any plans to buy another A9P for my car.
When you turn my car's key to the ignition position, the fuel pump doesn't energize. The inertia switch has power going through it, so I know that it's not tripped and is working properly. 12v power is being supplied to both the power and control circuits of the fuel pump relay. I verified that the ground wire for the power circuit is properly grounded, but the driver circuit in the ECM doesn't seem to be grounding the control circuit for the fuel pump relay and I'll tell you why. With the key in the ignition position, the fuel pump will energize and run if you connect the tail of a circuit tester to ground and then probe the ground terminal of the control circuit, on the fuel pump relay. By probing that terminal, with the circuit tester, you're grounding the control circuit, instead of the ECM driver circuit doing it, like it should be. To be thorough, I checked the continuity of the wire that runs from the control circuit ground terminal on the fuel pump relay to the driver circuit of the ECM and the wire did have good continuity.
When you consider everything I just shared with you, I can't see how the problem could be anything but a bad driver circuit in my A9P ECM. I just wanted to bounce this off of you guys to make sure I'm correct in my thoughts about what the problem really is here.
Any feedback on this would be appreciated!
throw the continuity test out the window, its useless
perform a voltage test at the ecm on the ground switch
lets just say the ground is good
what would prevent, other than a failed ecm, the driver from grounding?
better, what are the conditions needed for it to ground?
knowing that, you can test correctly,,,,you might be missing something???
part swap?
Is there a shop or someone that specializes in checking ECMs? I'm going to be putting my A9P in with the HCI swap soon.
Check your local AutoZone. You can still get remans with or without a core exchange, about $100 w/exchange.
No. I have a kill switch installed right before where the ground wire for the control circuit enters the ECM. I was getting good power through that switch, but the circuit wasn't grounding, so I grounded the circuit right before where the wire entered the ECM. When I did that, the fuel pump energized and worked as it should. That told me that the driver circuit in the ECM wasn't grounding the circuit like it was supposed to, verifying for me that the problem was, in fact, the driver circuit in the ECM, as I feared.
did you verify the input that tells the ecm to energize the driver?
the ecm only grounds that when it has the proper inputs
1 - 9 of 9 Posts
