I have an Autopower bolt in roll cage out of my time trial car.
It's for a 79-93 Hatchback, is in good shape and has never been in a wreck.
$250 obo and is located in the Culpeper VA area. Cannot ship but may help with delivery if not too far.
Jamie
180 miles away. I think it could be used as a 4 point bar you would just not use the front portion.There would be the 2 pieces for the upper roof bar and door bar that would stick out about 6 inches. They shouldn't be a problem and if you didn't like them aesthetically you could always cut/grind them off. It would fit with the interior although like with any bar/cage you would have to drill/trim interior pieces to make it work. The rear wheel arches are one area. In order to bolt the cage/bar to the inner wheel well you would have to drill a 2" hole in order to get the 1.75" roll bar through the plastic inner wheel arch panel.
Jamie
SOLD to Hammer Down..... Thank you
