1 - 14 of 14 Posts
So yeah like the title states, what do you guys think it would be like to autocross with a big block under the hood? Does anyone run a 460ci V8 big block or bigger and autocross with it? Reason I ask this question is because I am building just this, a 466ci autocross terror with a 4spd top loader tranny behind it. Let me know what you guys think.
Shane
I probably should have mentioned that this motor is going in a '92 Thunderbird SC (see sig) not a mustang. After I put aluminum heads, intake manifold, carb, and any other aluminum or light weight bits on it, it should weight a little more than the V6 with supercharger and all related parts that come stock on this car. Plus you have to factor in that the engine bay is currently gutted along with most the rest of the car. Should make for some interesting times.
I'll post up some pics of the car later tonight.
Shane
green94_gt said:
I like the idea how many cubes are you going and which heads and intake. And what trans.
466ci is what I am going with for now so not to get to crazy. I want to run aluminum Ford racing John Kaase super cobra jet heads if I can aford them. If not maybe a set of Edelbrock or TFS aluminum heads. An Edelbrock performer RPM, or Victor jr intake manifold is what I plan to run. A top loader 4spd manual tranny from an early mustang will handle the work load. All in all I am pushing for 500-600rwhp.
Shane
Anyone else have any other opinions about my project?
Shane
Shane
Yeah. Good Luck.
Should produce interested results, not necessarily interesting times. Unless sort of slow is interesting. A huge car with a huge, heavy engine...hmmmm.....I have enough trouble in my fox body that weighs roughly 3000lbs and has just under 300 hp.
I just don't see how it will become an autoX terror. Have you autoX'd before?
92MNstanger said:
Yeah. Good Luck.
Well the car dementionally is big but it does not weight all to much. Its finally weight is probably going to be somewhere in the 3200-3400 pound range.
Yeah I have been autocrossing for 3 years now.
Shane
My gut says you're going to spend a lot of time spinning the tires, unless you can set that big block really far back to get a decent weight distribution. You'll get spanked by stock Miatas due to the poor weight balance and huge width. But if being non-competitive doesn't bother you, you'll have a lot of fun in a good looking, unique car. Put as much tire as you can under that bad boy. Hoosier makes a nice 27x14-16 road race slick, should be just right.
Justin
Well if you've already started building it I have no advice, but Ford sells 460 aluminum blocks or crate engines or something. Saw a writeup about it how it doesn't weigh much more than a stock 5L, which is a good thing.
Personally I'd go for a 408 though, since you can make just as much power but with a small block.
If you can get the front end light enough that thing will be a blast to drive. It may not be the most competitve car but being able to boil the tires down in any gear always makes me smile.
Well even if you get the same top hp and tq numbers on a dyno, small block power just isnt the same as big block power. The ungodly low end and flat torque curve and extra cubic inches makes a big difference.
Discussion Starter #13 (Edited)
Weight disribution stock is nearly 50/50. All I would have to do is take 250lbs off the noise and move it to the back and its a perfect 50/50 balance. Now stock the SC weighs 3860lbs with a full tank of gas without me in it. This car weighed in at 3200lbs race weight with driver so I am thinking with the 460 in it the totall weight will go up a few hundred pounds probably. Plus the fuel cell that was put in is behind the rear wheels so that should keep the rear planted somewhat.
Guys you seem to have forgotten the SC handles nothing like a mustang. For my first two years autocrossing I raced my 35th anny SC with a race weight of 4000lbs and would finish in the top three at every event I would particapate with the car and its got 196k miles on the suspenssion. I can keep up with my buddy's Cobra, beat GTOs, Mach1s, hang with Z06s. I ran on 225/50/16 Hoosier autocross compound tires that I baught 3 years old used and they had half their life left in them. It was a blast running it and only making 219rwhp and 337rwtq but it lacked upper end power. Now I have a different car and an entirely different engine combo. I think it will be rough around the edges at first but mid season I think it will come to.
Shane
1 - 14 of 14 Posts
