I'm a autocross newb and was wondering if i could get some help or assistance on what class i might be running...
02 GT (boss legacy) mods are as follows.
T-56 6 spd, MGW short throw, H&R Supersports, Lakewood drag shocks and struts (going with Maximum motorsports springs and bilsteins HD shocks and struts), Maximum Motorsports Caster Camber Plates, 4.10 gears, Forged 31 spline axles, 31 spline T-Loc, MMR upper and lower control arms, aluminum driveshaft, aluminum flywheel, jlt cold air, 75mm throttle body, upper intake plenum, catless x pipe, slp lm1 (going to put mac on to quite it down) FR500 18" wheels, 275/35/18 KDW II's front , 295/35/18 KDW II's rear, Bullit brake kit
Also probably going to be adding full length mm subframes
So any idea? I plan on using street tires the entire time
X2 on CP or SM.
Since you will be running street tires, ask if your local region has some sort of indexed street tire class so you don't get lumped in with full slick tired CP cars or the SM monsters.
DaveW
