Any of you auto guys who have 3.73s, could you please tell me the rpm and speed of your 1-2, 2-3, 3-4 shift points on WOT (OD on or off)?
Can't tell you exact RPM, but I assume near redline/at the peak of HP (all of them), MPH depends on gear ratio, and you can calculate MPH from RPM using gear ratio, wheels diameter...
Plus there shouldn't be 3-4 shift under WOT AFAIK.
NorthwestGT:
Mine shifts at 5400 rpm at WOT with OD off. I don't do it too often but all of the shifts occur at about the same rpm (within 100 rpm of 5400).
I'm heading for a dyno tune at the end of April and I'll see what the tuner does (if anything) for shift points.
Hope this helps.
