As you know, Ford tunnel tested the rear wing on the 2000 Cobra R
Using a angle gauge, would someone please tell me the angle measured at the wing end cap, or from the front of the legs which support/hold the wing... while the car is on level ground -or better yet, measure the angle from the rocker panel which presumably is level with the ground.
I understand this is a unique question. I have this wing and I'm thinking about a retrofit and unless I get the angles right, I won't be any closer to matching the tunnel tested final results.
Thanks in advance
