1 - 12 of 12 Posts
Its fine, they will be gone in 30 seconds after its running
Really?? Cuz I have seen 100,000 mile motors with the cross hatch still clearly visible. If those lines are gone then you've severely overheated the cylinders and glazed the bores.
EDIT* Never mind. Need to open my eyes a bit more. I see the lines he was referring to now. Where's the facepalm emoji??????
It’s a 331, custom cam, 195 heads, 9.5-1 comp, systemax intake. Is there anything else I should do to get 350whp?
Easy. That's a damn good head and intake combo. I was making 1.4 HP per CI with a 347 with that setup and Eds cam. But he always tends to go big with me.:smile2:
Yes. I have a set of those. They come with adjustable guideplates, arp 7/16 studs and afr 8019 springs right out of the box. Awesome heads!
He just said 195 heads, you know it’s afr though so should easily meet his goal.
1 - 12 of 12 Posts
