1 - 9 of 9 Posts
Well I'll try to describe this the best I can. In reverse and first gear the car shudders right about 950rpms. It's just about when the car is at a slow roll. I am also getting a "sweet" smell when I feel this. I know this is not a good desciption but any suggestions? Thanks.
Sweet smell would probably be antifreeze, possibly a bad heater core or a leak somewhere. How bad is this "shudder"? I am guessing that this is engine and not tranny related. Without more info it's hard to tell.
Actually, I just got back from school and I think it might be engine related also. The smell seems to be the smell of gas. I have a seperate trans cooler so I dont think it's leaking internally. And I checked the trans oil when I got home and it seemed ok. A little darker then I like but it might just be time to change it. So I'm thinking it might be a fuel related issue.
Have you changed the fuel filter lately?
Yeah I actually changed it along with the PCV valve about 2 months ago. Here is what I have determined. At idle or part throttle it has bad hesitation and it is fuel that I'm smelling. I am going to pull the plugs and look at them and also try to clean the mass air meter. Any other suggestions on what I can check?:confused:
Check the injector o-rings to see if they are leaking for the gas smell. Also check your fuel pressure to make sure that the fuel pump is working properly. Let me know what happens.
Update:
I changed the plugs and the coolant temp sensor and then I cleaned just about any electrical connection that I could get to under the hood. The problem is now gone. I am betting it was the coolant temp sensor though. The one I pulled out looked pretty old. Also my car was running a little warmer than usual but that peoblem seems to be gone now.:D
Glad to hear that you fixed it.
1 - 9 of 9 Posts
