99-01 GT AOD
When cruising with the over-drive on, say around 45-55 does anyone notice the car jerking a bit? When I turn the over-drive off it feels fine. How many of you leave the over-drive on during day to day driving?
Thanks,
Jeff
Grn935oh:
You may get yelled at for using the term AOD because you have a 4R70W transmission. The AOD has not been used in the Mustang for a good number of years. Anyway...
You might be feeling the torque converter locking up and unlocking. Is the jerkiness associated with a change in rpm (say, 300-500 rpm difference)? Does the problem go away at a higher speed (like 60 or 70 mph)? lower speed (like 40-45 mph)?
I leave OD on. The only time it goes off is if I am going to do some WOT runs or if the road becomes quite hilly and it is shifting in and out of OD (by itself).
HAven't had the '01 for that long and never had automatic "4R70W transmission" either. I will have to do a little more research on it before the next post. :eek: I've always had a
T-5
I guess I would say it is just at low speeds and slight throttle changes. I was just wondering if this was normal. I notice if I try to use the cruise control between 45-50, trying not to speed (foot gets really heavy!) As far as the over-drive, I only turn it off when getting ready to make a calculated pass or WOT. Thanks for the heads up on the 4R70W!
Grn935oh:
I was a 5-speeder, too, until I came across my '98 GT!
Required reading is to be found at tccoa.com under the Tech Articles/Transmissions section. The article is "Transmissions 101", written by Jerry Wroblewski, the rather clever fellow who designed the 4R70W and now he works for Roush. (He is a wicked tuner, too).
A couple of chapters focus on modifying the separator plate to improve shift speed and firmness. This is the "Jerry mod" that you may read about from time to time. May I suggest that you consider doing this and your driving enjoyment will increase 100%. And add a tranny cooler, too -- your trans will thank you.
chris
