Do you guys mount the bearing plate positive or negative? Is the strut top suppose to be pointing inwards toward the engine or more outwards away from th engine for a mustang lowered 1.8 inches?Please provide pcs of your installs if possible.Thanks.
Yung Than:
The instructions say that "most cars have the bearing plate in the positive orientation". Well, you will be limited to about minus 1. If you want more (and I was told -1.5 is the max for street before wear becomes a problem), then mount them in the negative orientation. The Auto-X forum here is a good place to post your c/c plate question(s) -- those guys are very knowledgable.
