I am going to upgrade my combo over the winter. Right now its a 351W trick flow 170's s-trim on e85 12psi. It made 611rwhp this spring. The s-trim is about maxed out. Over the winter I'm going to freshen up short block get some TF 205R heads and swap intake to ifs-r. I would like to make 750+ through my 4r70w. I have just been thinking if the ti would work good or should I just goto the YSI?
I have a TI trim and it seems great for a street car. I see 20 lbs of boost and make almost 700 hp to the tire. Builds boost at a reasonable rpm.
you probably can't upgrade your strim to t trim if you were thinking you can. I tried but T requires HD bearings/case.
I just went from a PT7675 turbo set up to a S trim, was really missing the power...just bought a new YSI, this thing is fun! Just go to the YSI, do it once instead of twice...
