Is there anyone on here that is running this kit with A/C? I know Quick Time is becoming a sore subject but I need some help figuring how this kit goes together.
Discussion Starter #2
By jturmanator, shot with COOLPIX L5 at 2008-09-03
One problem I have is getting my upper rad hose on. Turbo is in the way i cant move radiator up anymore, it will hit hood. You can see my condenser lines below the turbo, i have no room to clock the turbo. :confused:
No way! I just bought this Mishimito. What radiator did you get? How did you route condensser lines?
Use an -16an upper radiator hose. If you cut the neck off the radiator and weld the -16an bung, use 90* hose ends and a CSR -16an thermostat housing and the problem is solved.
Check out half way down my build thread for how I did mine.
http://forums.corral.net/forums/showthread.php?t=1038793
I cut my radiator hose where it angles down to the radiator, it just barely touches the turbo. Hope this will work.
Now I'm trying to trim the front valance around the intercooler. This requires more trimming than I was lead to believe. Does anyone have pics of there intercooler set-up?
