1 - 19 of 19 Posts
I haven't heard of too many cars running this heads. I have this heads in mine but I am thinking of porting them. I wan to know if there is some high horsepower potential with this heads.
NMCA mean street cars have run high 8's with the vic jrs and a plate kit, so they have potential.
Thanks, I took my car to the dyno and it put down 364rwhp only (
342ci). The engine had timing pulled for a 100shot but I was real dissapointed. I am thinking of porting them and getting a bigger solid roller cam.
66notch, can you give me details of you combo? you running N/A
Subscribing..... I have vic jr's also(outa the box) on a dss 331 10.5-1 comp,Holley systemax II, 80mm 30lb injec, mac exhuast and 456 gears in a 5spd best so far is 11.90's.
Yes N/A. 408w, around 11:1 compression, fuel injected, hydraulic roller cam, super victor intake, Mac longtube headers, MT 275/60/15 DR, 4.10 8.8 and a C-4. Street driven and to the track but not DD. I have only run the 1/4 mi once our local track is 1/8 mi.
Paul
Something is bad off on your combo to be a 408 with 11:1 compression and only putting down high 300s HP. You need to get that car to someone who knows how to tune a mustang.
PMS Tuning Forum Moderator
My 347ci runs 10.50s with a 205cc cylinder head I would like to think that 210cc is plenty for you.
My brother runs stock Vic Jr's on a 434 with a 250 shot and runs 5.80's in the 1/8th at around 118 mph @ 3200lbs. N/A it runs 6.50's.
I just ran a 6.65 103 mph with mine last weekend with my new cam and C4. But broke the tranny the second day on the first run.
Running mid 10's with the Victor Jr Keith Craft stage III ported. Stock computer that needs a tune.
6.10-6.15s @ 111/112
393, early model block, n/a, 13:1
ported victor jrs
stock super victor intake
solid roller
c4 with a junk tci super street fighter converter
15x9 draglites with 26x9 et drags
It weighed 2600lbs and was put together with stuff laying around.
Ran 5.80s @ 122/123 on 225
Discussion Starter #18
I've been away in business, but thank you all for the input. I checked out FoX Lake racing and Keith Craft. I don't want to do a complete overhaul, so I'll just send the intake and heads to one of this shops. Hopefully my 342ci will hold and I can have some fun.
well i have a new set of lightly ported ones in the box sitting in the front room. waiting on a set of crane valve springs that will hold back the 18 lbs. of boost the procharger is gonna pump to the 408w. thats the only catch about these heads from what ive found out....there good but the original springs wont seal properly under a fair amount of boost. as far as a n/a motor goes, ive talked to several speed shops that say there are some better heads out there but not much difference, and for the money you cant beat them.
1 - 19 of 19 Posts
