I got the dead pedal and clutch pedal changed out (that was tough enough, but I what I can't figure out is the gas pedal. It has a pin seems like, but it wont come out. Any ideas?
I've seen instruction around somewhere. I don't remember where though. I used another pin (or a nail in a pinch) and some large channel-lock pliers. I just used the pin to push the one out of the pedal, then used just the pliers to put the pin back in after I switched the pedals. Anyone else?
That gas pedal is a lot easier to change if you remove the whole assembly before drifting the pin out. Use some needle nosed pliers to gently pull the cable holder from the top of the pedal and slip it up and out, then 2 small nuts and you can take it out and straighten your back again.
