1 - 8 of 8 Posts
Corral Charter Member
Just curious, I'm running a 275/60 MT Drag Radial right now...
I want to see what guys are running on the 50 series (any DR), and what sort of 60' times are possible with the shorter sidewall.
I recently switched from a 275/60/15 MT to a 275/50/15 and I haven't gotten my 60ft back. I was running mid 1.6s and now my best is a high 1.7. I also switched the clutch from a king cobra (organic disc) to a ACT (ceramic disk). I just can get traction now...I think the clutch is shocking the tires too much. My datalogs were showing that the king cobra clutch was slipping on launch so I switched clutches.
The factory stock guys are running 275/50 BFGs and getting 1.5x 60fts so I'm not blaming the tire.
I've ran a 1.39 60ft on the 275/50/15 M/T drs on my 90 coupe.
Wow, 1.39? That's impressive. What kind of suspension, shock settings, and tire pressure did you run? Is it an auto?
Front: D+D K member with 125lb 14" springs,Strange 10 way struts a couple clicks off full lose
Rear:Old school Mega-bite jr lowers,HPM non adjustable uppers,Strange 10 way shocks a click or so from full tight,stock V-8 springs,air bag in the right rear at 25 psi.
C4 auto with rev. manual vb,NO trans brake,stall flashes about 4000-4200.
Usually run around 14 psi in the drs.
427 makes a lot of torque... that helps a lot. Car is about 3175 with me.
10.70s @ 125 rolling out then flooring it 1.59 60 ft on 2 year old bfg 275 50 15s
upr k member with coil overs
summit upper and lowers
90 10s and 50 50s
373s in the stock rear
12 psi of air in the tires
I seen a car down here that came to run in a low 5 second 1/8 mile class. It was an early 70s Chevelle. I was in shock when I saw the little 275/50 tires on it and that it was hanging with cars going 5.20s in the 1/8. He was competitive and I want to say I saw him crack off a 5.30 in the 1/8.
1 - 8 of 8 Posts
