1 - 13 of 13 Posts
taking the coupe to osburn saturday and wanta get some estimates.
coupe weighing 31?? lbs.
347
victor jr heads/ intake
x 303 cam< not by choice
42lb injector things
76 mm maf
75 mm t/b
centerforce df clutch
t-5
aluminum d/s
4.10's w locker
control arms of unknown origin
1/8 MILE
just wanting some guesses, i wont be launching it as hard as possible. prob more like a quick take off. powershiftn
like crap, cam is not even close for the heads and intake.
hints the not by choice beside it. its a street car. same motor w/ turbo, aod and less injectors went 11.00's at 126 +,but that was then. turbos gone, aod blown.
i saw that next to it. sell me the heads and intake and use some performer stuff if its for the street, lol.
ya but i like the torque on the mid to upper range. :leghump:
traction will definitly be the issue, thats y i wont be hammering it out of the hole, ( banger t5 and street tires)lol.
i was hoping for low 8's. in the red car that motor ran 8.20's all day with 2 gears. :cool:
don't powershift it unless you want to be a one hit wonder . . .
I say if you can't run under a 7.60 then you can't drive (limited by trans/tires).
The MPH should give a clear indication on what kind of power it is making.
I say 370 or so rwhp
ok so the first pass went crappy, then about a hour later it started raining.
but hey i got a 7.92 in in that time period. made my friggin day
347
76 mm maf
75 mm t/b
t-5
aluminum d/s
4.10's w locker
1/8 MILE
I would agree that it could clip 7s but im curiouse to know what it made a dyno... as far as the et goes definatly depends if you hook or not
Your happy with 7.9's out of a 347?
Same thing I was going to say.
A near stock 302 and some good driving will get that.
On a better note,
The motor has most of the parts to make the car capable of high 6s. A cam change, traction, and a decent transmission (Tremec) will put it there.
Discussion Starter #13
and im not gonna call you a liar, its gota banger 5 spd in it and thats all i got.
1 - 13 of 13 Posts
