has anyone used this cam?
my setup will be twisted wedge heads and track heat intake on a 306. it will be on my dialy driver so i need it to do pretty good down low. does anyone have the specs on it.
thanks for any help.
I don't know what thy changed from 41 to 412 (possibly nothing), but it can 'buck' below 1200 and doesn't have much power below 1500, but on my dyno I had >300 rwtq from 2800 to 5500, with a peak at 3800 which is relatively low, a lot of usable power for the street. use 4.10s at least and you'll be happy.
n-41 specs are 222/230 @0.05, .512/.512, 110 LSA installed 106 ICL
i think the 41 is supposed to be a little better high up in the rpm range. and the 412 is a little different, it suposed to be a little better down low. i think
