1 - 12 of 12 Posts
I have a 91 coupe with 306,trick flow twised wedge heads thats been ported,500-500 lift cam (custom grind), 1.6 rockers,edelbrock performer rpm upper and lower, 24lb injectors with pro m mass air. t-5 with 3.73 heres timeslip. first time running with new setup.
.28 reaction
1.699 60 foot
7.800 1/8 mile
88.998 mph
I know there is more in the combo, I know my 60ft isnt there. what should this combo run??? any help is appreciated. thanks
I have never weighed my car or had it dynoed it either. I bought the mototr from a guy and he said it run 7.30 with a automatic. do you think thats possible???
We need more info......
What tires? What launch rpm? Is it spinning or bogging? What kind of suspension are you running?
Iam running 26x10.5x15 mt et streets, 4500 rpm launch poing car was spinning a little bit not to bad though, I have upr upper control arms non adjustable, southside lowers, 50/50 rear shocks, moroso trick rear drag springs, stock front struts and springs. I need some 90/10 front struts and different springs.
MPH would put you around 7.55 if the 60' and early numbers were better. Not much more. Need to run 92-93 mph to make that 7.30 mark.
I ran 7.87 @ 88mph...I really don't think I had a 7.5x in the car. My friend at the line that was next to me when I launched did say that I spun about half a revolution, but I don't think that would make up .2 - .3
i checked my timing and it was to high, i was also shifting the car around 5800 and the guy i bought the motor from said he was sifting it around 6400-6500. iam going back to the track soon to run it again. hopefully it will run faster next time out.
1 - 12 of 12 Posts
