1 - 11 of 11 Posts
Not sure my alternator is charging. How do I check output on it. It's a 3G on an 87 mustang. The batt and alt are new. Tia
I don't have one. All I have is a regular meter. Check voltage at battery with a load. Like headlights on. Voltage should stay fairly steady?
All loads on, ie blower on. High
Voltage at battery should be 13.5-14.5volts
Also check the fuse able links one might be damaged causing low voltage they should be next to the battery if engine bay hasn't been altered last I remember they are green in color or gray
  • Like
Reactions: 65 K car original1!
Check the voltage across the battery terminals with the engine OFF by setting your volt meter to 20 volt scale. Attach positive lead to positive battery terminal. Attach negative lead to negative battery terminal. Voltage should read around 12.5 volts. Then start the engine, the voltage reading should spike up to 13.8 - 14.2 volts. That indicates the alternator is charging. Turning the headlights and heater ON, the 13.8 - 14.2 volts should still remain the same.
1 - 11 of 11 Posts
